Xandre
- Jul 18, 2006
- 143
I've been scouring the foum for a solution here but am having a hard time figuring this out:
Is it possible to directly connect a Bilge pump to the battery and avoid going through the boats electric system?
I read I need a fuse close to the battery? What type of fuse? Is this available on iboats.com?
There are 3 wires- Brown/white, Brown and black. Do I simple peel pack some of the plastic and insert the wires below the wingnuts on the battery and tighten it down? Which wires go to positive and negative?
I know nothing of electrical work and when I look at the pump, the boats electrical system and wiring diagrams I feel clueless.
I bought a Rule 500 automatic pump and simply need it to hook up to the battery to keep rain water out of my small 14 foot aerocraft. I don't need any alarm, float switch or on/off switch on my dash. Just want it to be able to pump rain out when I don't get down to the boat for a day or two.
Any thoughts for a complete novice on electrical? =)
