Bigmykesboat
- May 10, 2012
- 16
hey guys thanks for all your help to get to this point ive learned alot just by reading what every else has posted first let me start from the begining i bought a boat an i checked it it started in netural went into forward when given forward power an went into reverse no proublem hears where it all went wrong i took it apart to put a new impeller in when i took the foot off i dident know there were two wires i had to disconect so half way out i freaked an took the hydro electric shifter cap off to get the foot off. We meaning ya all helped me rebuild the water pump an that went great but when i put it back togather i also changed the lower unit grease with citgo marine plus type c for sae 90 an 80w-90 or 85w 90 when i started the motor it started in forward an i couldent get it out of forward no netural no reverse so i took it back out an checked the plunger on my bench with it out i grounded the foot an touched the blue wire an the plunger went up or down not sur touched the green wire the plunger went the other way so i put it back in an tested it on the bench an i heard it making its sound with both wires so i thought good to go put it back in conected wires blue an green started it up still in forward so i switched the two wires green to blue an vise versa still no change so i took a jumper wire to each wire then to both every combination no change i went bacjk an read posts an saw where it said what wires should have how much voltage from the shifter so i tested that green an blue from the shifter an they are dioing what they are suposed to do right voltage right time so im good from the shifter an my solinoid is making its sound everytime i hit it with juice now im second guessing the oil? i dont know what to do next is there a way i can bench test it ?dose this sound like anything anyone has run into thank you for all your time an help MYKE!!!!!!
