Re: Bayliner Trophy planning problem
Basically your boat is like a sponge, over the years the foam that is used to stop your boat from sinking to the bottom has become water loggged.
I am not sure what you mean by waterlogged floatation foam. ?
Now back to the problem. Know nothing about inboards, but I know tons about under powered boats living in Colorado.
First we kneed to know if the motor is being trimmed in all the way , just like all the other posters said, because a trimmed out motor ='s a high nose, normally. take a batter picture of the motor from a few feet back trimmed down all the way, so we can see the whole motor and more of the boat, make sure the camera is level. Then determine if it is in fact being trimmed in all the way, If yes, take the boat out on the water with just 1 person, and only the necessary safety gear, trim it all the way down and see how it goes.
How long does it take to get on the plane like this, ???
Then we will know some more information.
Now what Maclin suggested sounds strange, but then is nothing strange about what can go wrong and will go wrong with boats.
But its either two things.
Boat is too heavy for motor, or there is slippage getting power to the prop, anywhere from the top to the splines. if the motor is running correctly, for example on your outboad when its cold outside, if the motor is only running on 2 cly instead of 3, there is no hope of getting on the plane.
I almost forgot , if there are lots of people onboard them more them to the from if you know that boat can get on the plane with 2 normally for example.
