Re: 83 125 chrysler force parts cant find
The prop shaft is the same for late Chrysler and early Force engines from 1979 up until about 1988. It is the same for all engines from 85 up to 125 horsepower. The only difference is that early models have an extended length for a tailcone mounting while later models do not.
Do not buy a new shaft from a website. By the time you do, you could have bought a used lower unit for about the same price. I have several extras, but way out there in Saskatchewan, shipping and import duties will absolutely kill you. Try to find a junk engine locally and salvage the shaft or lower unit from it.
If you absolutely must buy from a webside check here at iboats first. Then google outboard parts and several dealers should show up.
