Brandonmartin
- May 4, 2012
- 3
Good morning all. I recently purchased a Power-Cat 15' Runabout catamaran. Not a sail catamaran, just a runabout with a catamaran hull and a 80-HP outboard. It is a model "15-T". My question is: I can hear water splashing INSIDE the pontoons. There are no holes in the fiberglass hull......I am guessing the water seeped into the flooring and then dripped down into the hull voids. How do I get this water out? Do I abesolutely need to (will it eventually rot the fiberglass hulls)? Hoping dot to drill a hole into the hulls! Thanks for any advice you can give!
Thank You,
Brandon Martin
Olympia, WA
3rd Mate - US Merchant Marine
Thank You,
Brandon Martin
Olympia, WA
![IMG_1130[1].jpg IMG_1130[1].jpg](https://forums.iboats.com/data/attachments/124/124327-dde8689fc34cb540b065ee71da950166.jpg)
