blueboat1998
- May 20, 2012
- 2
Posted this at Ohio Gamefishing but was referred over here...
This happened last year and I thought I had it fixed until it happened again Friday. It's a 19 foot Sylvan with a 115 Merc Fuel Injected 4 stroke. The main/tilt fuse blows for no reason I can find. Everything works with the switch off. Turn on the switch and it's a crap shoot. Sometimes it will trip the fuse within 2 seconds. Other times you can't make it do it. Yesterday in the driveway it blew every time for a while. I cleaned up every single wire that I could reach in that rat's nest of wires and then I couldn't get it to do it again. It frequently blows without the switch on and nothing happening. This morning it was fine when I left the house. I drove 7 miles and stopped to put some gas in it. Fuse was blown so I turned around and brought it home. Obviously there's a ground or short circuit problem somewhere but I just have no more tools to troubleshoot it further. Unless someone here has some genius advice it's off to the shop. I don't even care as much about the cost as the fishing time I'm likely to miss.
Thanks for any ideas.
MC
MC
