I am looking to get a stainless prop for our new to us bowrider.
Specs:
2005 Chaparral 210SSI
VP 5.0GXI 270HP SX outdrive 1.6 gear ratio
Quicksilver 1918P21 prop 14.25"X21P 3 blade aluminum
3 adults and full of fuel 4950RPM at 47MPH
The holeshot seams reasonable and the RPM's are good but I can not get the boat light in the nose, it will not porpus even at part throttle. Any more then 1/8th trim and the prop starts to slip and the motor goes to 5400. The prop also slips if it is more then a little trimed up when you turn. The prop is like new and seams to have plenty of cup. Looking for best cruise and top speed but will be pulling the kids on the tube some as well.
Specs:
