chriscraft254
- Jun 4, 2011
- 2,445
Splashed the boat today, great day except I have a leak from something behind the motor that I have no clue what it is, maybe someone here will and maybe know where to order a new one.
Its cylinder shape, has a hose coming off it from both ends two other ones coming off ht sides. The one on the bottom goes out towards the outdrive. The hoses are not leaking, I think whatever the cylinder shaped thingmabob is has a rusted through place on the underside. It was leaking water while motor was running to the point that the bilge pump kept coming on.
Once I found the leak, I kept an eye on temperature and I got back to ramp and pulled the boat, now just need tofix it . Temp actually stayed fine.
This is a 1990 Chris Craft 254 Seahawk which now has a mercruiser motor but omc outdrive. The part is obviously something from the old motor which was an omc 5.7 liter.
Any info you guys can give me on what it is for and what its purpose is will be appreciated. Obviously it has hot motor water running through it. Where it was leaking, it looks like someone had already done a half azz repair with some epoxy or something.
Here are some pics of the part in question. Thanks
