kfa4303
Banned
- Sep 17, 2010
- 6,094
Hi all. Went to fire up the old beast ('66 20 hp) today in prep for a trip tomorrow and noticed that the motor was running poorly. It was revving up and down without any input from the throttle and was difficult to start, which is odd because it's usually a 1-2 pull motor. I realized that I had a fuel delivery problem due to an air leak somewhere in the fuel line. One of the fuel hose adapters seemed bad, so I went and got a new one. Now both fittings on either end of the fuel line leading from the tank to the motor are nice an snug. However, my fuel lines are not filling up as verified by the clear plastic fuel filter I have inline btwn the fuel pump and the carb. While it doesn't always stay full while running, it does usually fill when I prime the bulb prior to start. Now, no matter how much I squeeze the bulb it never fills. So I'm pretty sure that my primer bulb is bad, but I'm not sure how to test it to see if it truly is faulty. I tried disconnecting the fitting from the tank end and stuck the fuel line straight into the fuel to see if I could squeeze the bulb and get the lines to prime that way, but no dice. The bulb itself looks perfectly fine on the outside, but I'm thinking the valve(s) inside may be on the fritz. Somehow it just doesn't "feel" right (very subjective, I know). Anybody know how to test the bulb to see if it's good bad, or ugly? Thanks.
