Mercury 45 HP-serial#0B100305
I have 2 oil plugs in my lower unit that appear to be the same thread an pitch. The top plug has stripped out the threads.
I want to put a helicoil in it.Can anyone tell me what the thread and pitch is?
I have the lower unit torn down to do the helicoil. Behind the prop there is big plastic nut that holds the bearing + prop shaft assy in the lower unit. My service manual says the nut should be torqued to 210 ft lbs. Is this a misprint? Should it be inch lbs
All help appreciated. Thanks
Ken
Ken
