hi everyone , i just installed a new pioneer 1300 series am fm cd radio , it works great, the only problem i am having is it will only pick up four stations , does this radio need an amp or a better marine aerial ? thanks ..
Re: installed new radio but only getting 4 stations ?
hello , the antenna is 1989 , where the marine antenna is i dont know . the old radio picked up about 12 stations , and i dont own a camera ,. thanks .
actually sometimes you can, depending on how close they are to you.......since they are so cheap, i could suggest a 6.99 auto zone replacement, will it hold up? maybe for a few years, but for the money, what the hay???
Try rotating the male antenna connector inside the female end on the deck to make extra sure that you have a good, solid connection. Check your male plug for any corrosion. Since it's a 23 year old electronics item, I'm inclined to think the problem lies with the antenna..
