Ststephen7
- May 19, 2012
- 2
OK... I have an 89 evinrude 25hp. The starter doesn't rise up and engage the flywheel when I turn the key. It does engage the flywheel when I jump straight from the battery. The solenoid does click.
I am following the troubleshooting instructions I found here as best I can. http://forums.iboats.com/showthread.php?t=158071
I cleaned all of the connections: at the battery terminals, the starter, and the solenoid. The wires seem fine (to my untrained senses).
The voltage at the battery is 12.78
The voltage going into the solenoid on 'run' is 12.78
The voltage going to the starter from the solenoid on 'start' is 10.65
The troubleshooting guide states what to do if I find 12v going to the starter, and what to do if I have less than 9v going to the starter... I'm in the middle at 10.65, and I'm not sure what to do now. Any help will be greatly appreciated. Do I need a new solenoid?
Thank you!
Steve
Thank you!
Steve
