I have been doing some cleaning up of the old boat and have been trying to find some touch up paint for the bottom hull due to some scratches but have not had any luck .they are only about 2 or 3 that you can see on the side of the hull that i would like to cover up .It has a Grey bottom but out of auto tuch up paint i have not found anything close yet.Any recommendations
Also the second question i have is my boat is equipped with a jack plate but i was curious if it may be sitting to high or possibly to low.how would you check to see if it is at the required height.The boat is a 1999 javelin Renegade 19 with a 175 Johnson at 24 pitch prop (which is to big of a prop from what i am told)original owner put this prop on for some reason
Not the best pic but all i can find at the moment
