scimitar858
- May 16, 2012
- 39
Hi All,The engine will run for a few seconds,but only if i remove the carb and spray premix directly into the inlet manifold, when i replace the carb it won't run,not even if i spray premix into the carb venturi,i've stripped the carb, blown all the airways and gallerys out,and it still won't start,i also have a spare carb, of which i've done the same to,and get the same result,is there something i'm over looking,it's as if there isn't enough vacumm to drag the fuel out of the carb.
There is also a pipe which runs from the bottom of the inlet manifold, to the bottom plate beneath the plate which the fuel pump mounts too,this appears to be a vacuum pipe,but fuel comes out of the outlet to it in the inlet manifold,is this normal.Many Thanks in anticipation Phil
