1975 Mercruiser - Condenser
JasonM
I have a 1975 Mercruiser 140 with a mallory distributor. The engine has been completely redone. The problem I am having is the boat will run great for about an hour and then it starts to bog out and then it stops running. We found that the boat keeps blowing condensers. When we replace the condenser it will start right up and we are good to go for another hour. When we opened the distributor to replace the condenser we noticed metal type shavings/pieces. Also the distributor was really hot to the touch? What would cause the condenser to keep blowing out? I was going to replace the distributor to see if that helps. Any advice would be greatly appreciated.
Haut Medoc
Re: 1975 Mercruiser - Condenser
Welcome to iboats :) Are you using the original coil or did you replace it?.....JK
JasonM
I took the old coil that was on the boat to the parts store and they gave me what they say is the correct one. Looks like the same one.. I am a little concerned now. Can you shed some light on what the correct one should be??
Haut Medoc
I don't have specific info on your new coil type, there are many different kinds.....It seems like you are getting too much juice to the coil, and it is frying the condenser......Get the #'s off the old coil for comparison......Better yet, call a mercruiser dealer for the part #. If you went ot Dougrussell.com or Bammarine.com you could probably find it there.....Are you sure that the + side of the coil is wired correctly? There is a resistor wire that runs the coil in the 'run' position on the key, and another one from the starter that provides extra voltage with the key in the 'start' position. If you are sure the coil is right, Merc. manual #2 says Prestolite #32193....If you do have the right coil I would look at the resistor wire.....Look in the "search" function, there are tons of useful posts on the subject...JK
Dunaruna
Originally posted by JasonM:<br /> When we opened the distributor to replace the condenser we noticed metal type shavings/pieces.
Apart from the condenser/voltage issue, you need to remove the distributor and investigate.<br /><br />Aldo
JasonM
What is the wire that goes from the negative of the coil to the side of the distributor? Does it need a resistor?
Haut Medoc
The brown one? Ground ......And the other one should go to the shift interrupter switch.....JK
Haut Medoc
Oh, and no resistor there, the white one (+)is the resistor.....JK
JasonM
I am going to check the coil and then I am going to open up the distributor. I will probably need more help down the line. Thanks for your input
JasonM
Well I bought a new distributor and when I took the old one off and turned it upside down the guts of the distributor were falling out. There was a bunch of plastic and metal fragments as well as a spring. I put the new distributor on and the boat ran like a champ. <br /><br />The boat has a new engine and the only problem now is that it will not go above 4800 rpm's. At the beginning of the day we could only get it up to 4200 rpm's but by the end of the weekend it was up to 4800 rpms before it would bog down. I talked to my father in law who I bought the boat from and he said that it is because we havent really broken in the engine yet. Any thoughts?
Bt Doctur
If you have "resistance wire" in the circuit, coil says "use with external resistor". using a standard coil here will reduce the voltage going to the coil because the coil has a resistor built in. Plus there is an "electronic ign. coil" specific to breakerless systems.
JasonM
Yes I have do have a wire and the coil does say "use with external resistor". Any other thoughts on why it wont go past 4800 rpm's.
Haut Medoc
Jason, glad you figured it out.....A 140 is only supposed to get 4200-4600 R.P.M. @ W.O.T., if you have the right prop. You will kill your engine by running at those #'s.....4800 is too much already.....JK
