I have a 1992 Alpha Gen II that after winter storage, I can't get the outdrive sea water pump to prime and deliver water to the engine/water pump.
Running at idle there is no flow, reving to 2000+ RPM produces intermittent flow. I have checked it at both the top of the engine and pulled the hose at the PS cooler on the LH lower side of the engine.... This is as close to the outdrive pump as I can get to check the water supply from the outdrive.... Still only surges a small volume of water. It is like it won't prime.
I ran muffs with garden hose full open and also in a tank of water filled to the anti cavitation plate. No differance ether way.
After dissassembly and cleaning the old impeller did not fix it, I installed a new water pump kit, including the housing, impeller and seals.
Still no flow, and what water does lay in the T-Stat housing overheats... (Normally out of the water, with no load, I can barley get the temp off the first mark)
I am a little unsure about the seal above the sea water pump impeller housing on the main shaft...It has a small thin lip in the bottom of the seal... Is it supposed to be lipped around the top of the impeller housing to hold it in place or does it just ride above the impeller housing?
The install tool didn't seem to push it all the way down, so I lipped it over the impeller housing between the shaft with a small screwdriver... Is that correct or could that cause the impeller to bypass water and not prime? (The old seal was too torn up to tell me how it was located)
Any other suggestions on what may cause it to not want to prime.
Any advice appreciated.
Thanks
Steve
Thanks
Steve
