01 150XL Carb Oil injection not pressurizing and hard starting
Motor started BEEP BEEP.... res. was low added oil and made it back home. Pulled the tube and it was slimy so I cleaned it up like new changed the oil and cleaned the tank. Now I ran it again and is doesn't seem to be getting any pressure to the tank. Pulled the lines and there clean no a drop of oil in them.
Next I pulled the pressure hose off the tank and started the motor. No pressure coming out of it and no suction either "which i know it should not do". Not sure what the problem is. Thinking maybe the crankcase check valve?
Also when starting the motor it take quite a bit of time to get it to start up. Cold motor or hot it takes cranking and cranking and priming and choke to get it to kick over. Once it's running it scoots though.
So problem 1. Oil injection what could be the culprit besides the check valve which I will replace also.
Problem 2. Very hard to start- tried choking for 5sec then a mech said do it for 15 sec, I have gone up to 1 min in 10 sec intervals with the same result. Only way I have found it crack throttle a bit Prime the bulb choke for 30 secs crank for 30 secs and repeat and in 5-10 mins of that it will kick a bit and eventually start with bit of smoke and it runs clean after that.
Any help is much appreciated
