When I was reinstalling the lower unit the other day, the drive shaft splines weren't lining up properly for reinstallation. So I put the lower unit in reverse (using the driver's seat shifter) so that I could turn the prop and line up the drive shaft splines properly. It worked and I got the lower unit reinstalled. But I later found out, not correctly.
Well, I took it out on the lake the other day and found that the lower unit is now stuck in drive; no neutral and no reverse. So I dropped the lower unit again and messed around with the shift shaft to try to get it into neutral. It doesn't seem to want to go into neutral with me turning the shift shaft by hand. I marked it with a black marker and found the limits of the rotation and tries the middle and everything between the limits while turning the drive shaft by hand. Am I missing some step? When using the shifter at the driver's seat, it appears that the upper unit shift shaft barely turns between drive, neutral, and reverse.
Any tips to get the lower unit back to neutral so I can install the lower unit back correctly? This didn't happen the last time I dropped the lower unit.
