I've got a 95 115 Evinrude crossflow motor. Right before I purchased the boat it was tuned up. I have the receipts and one thing noted is the idle jets were changed (to be leaner). This work was done at a much higher altitude than I am at. The motor has idled OK but I have always felt that there was a lean cough at times. I've got a Seloc manual and it does not state the stock size or any info about the jets other than to take out and put back in.
I have not pulled the current jets so I can't confirm size (I know it would help, will do this weekend). Can anyone tell me the proper size based on altitude? I'm usually in that 1000-3000' range. Like I said I feel lean right now. And, being that we are metering air, to richen the mixture I assume I need to go to a smaller jet?
Any help is appreciated, I've been a little disappointed with the Seloc manual so far.
