Reverse grinds and hard to engauge!
mnewcomer1
I have a Johnson GT150 1988 model; I changed the lower unit oil acouple of months ago and since My reverse is hard to drop in to gear. I can spin it manually and manually push it in gear. I have my cable almost adjusted all the way back, and it still is hard to pull in to place without it grinding. When I put it in reverse the cable kinda jumps, or bounces when in reverse. Do i need a new cable? Re adjust cable? What do I need to do? Forward is no problem at all.
Thanks in advance.
Damifudo
Re: Reverse grinds and hard to engauge!
LOL seems a little common I already asked that question above. I have has some good responces cables and shift shaft height needs to be checked first. I am buying new cables
