fishkilla22
- Jul 20, 2011
- 21
im using the c-91-24695a2 mercury flywheel puller. should i mark anything before removing the flywheel or is it ok to use the tool and just remove. and should i use the two bolt pattern or three bolt pattern. on the flywheel it says use just 2 bolt but in my service manual it says use 3bolt pattern?! any advice would help.
