Hello,
I was doing some maintenance on my Mercruiser 3.0. I changed the fuel filter and the sparkplugs. I expected the engine to be difficult to start at first and cranked it over many times without success. After reexamining, I noticed that one spark plug wire was not connected. I connected it and the engine started and ran but would stall at low idle (my original reason for doing the work).
After it stalled, I turned the key to start it again and no response. The battery is connected (horn and accessories work) but the instruments (fuel gauge, etc) do not move when switched to "on" and the "start" position does nothing.
Is the starter switch damaged or is there a fuse blown somewhere. I am getting power to the red starter motor lead. I have a multimeter, where do I start checking?
