Help!!! Im a 30 year mercruiser guy so Volvo Pentas are new to me.
I have a 1987 Barretta 16 footer witha aq 131a 4 cyl with a 275 outdrive. Basically got the boat for free and just finished deck rebuild and repaint. Checked engine for compression which was good across board (160 to 180) Replaced exh manifold, water pump, and cleaned up all electrical connections. Replaced wires, rebuilt carb., replaced alternator.
Got it running and idles good but seems to bog with heavy acceleration. Planning on replacing points with either new or electronic (hotspark or pertronix) and coil which I think will solve problems. Any opinions on which way to go??
Next major problem is with outdrive. Changed drive oil which looked very milky. Not sure how long it had been there. While running motor notice drive oil coming from mid point on outdrive. Appears to me that exhaust water must be getting into drive. Just drained new oil again and it appears milky. Bellows on drive appears to be relatively new and in good shape. Where in this outdrive could the exhaust water be getting into drive body? Water intake was from hose inside boat so not on intake side.
Thanks paul
Thanks paul
