Re: Sierra , Barr, osco manifolds
I'm going to ad something from my very recent experience regarding the Osco/Barr debate. I purchased two Osco manifolds to replace my cracked OEM's. Not impressed at all. Poor casting, threaded ports for water lines and drain cocks were almost unusable without additional filing/thread cleaning. Huge voids in the casting where they just filled it in with a patch. On one manifold, there was a small chip in the metal right on the riser mating surface next to a water jacket. Definitely sub par quality. As luck would have it, one of my risers was bad, so I took the opportunity to give Barr a try. MUCH better quality...hands down! The casting looked as smooth and void free as OEM. No sharp edges, no slag, no pieces of machining leftovers jingling around inside. Threads accepted water ports/pipe plugs without a fuss. Mating surfaces were mirror smooth with no imperfections. I'm stuck with the Osco's and am never going to feel comfortable with them on my new engine; but they have to fail before you can return them for a refund. I think Barr is the way to go if you want to be as new to OEM quality as possible, without the OEM price. Just saying!
