I'm now the proud owner of a 1998 Glastron GS-249 cruiser. It has a Volvo Penta
5.7 GS PBYC and VP SX-C1 Cobra 1:51 outdrive. It hasn't been run in several
years (not sure exactly how many) so I'm getting ready to clean it up and "give
it a go" as the Brits say. I'm a pretty competent shade tree mechanic so I'm
comfortable with this engine (Chevy 350) but wanted to get some tips on the
outdrive especially. I don't want to get it running then find out I should've
done this or that first and just ruined something expensive!
I'm OK with checking the engine compression, fuel system and ignition system.
But as far as items unique to a boat go, I'm worried about the raw water
impeller but not sure if I should test it somehow first, or take it apart and
inspect it or simply replace it first regardless. I did already buy one because
I read on these posts that it's a good idea to carry a spare anyway.
For the outdrive I don't know how to proceed much there at all. It's held up
with a nylon tie strap and I don't know how to deal with the hydraulic
cylinders. Do I simply remove the strap, let it down slowly and see if it
falls? Should I bleed off some hydraulic fluid to let them relax?
Once down I can check the gear oil for quantity and quality. The prop has been
removed (and I wasn't planning on buying a new one until it's proven to be a
good investment). I'm thinking that I won't worry about the seals and bellows
until it all seems to run then I'll buy and replace both prior to sea trials.
Is that a sound plan?
As you can see, I'm not very knowledgable about the outdrive, I thought about
trying to remove the whole thing and run the engine first and go over all the
outdrive bearings, seals, u-joints, bellows, etc on the bench but I can't figure
out how the engine would get cooling water that way or if that's more work or
less overall.
Any tips you experienced sea dogs can provide would be greatly appreciated! I
know there's a lot for me to do here but I'm not worried about taking my time so
if someone would be wiling to give me a pointer on the first thing or two to do
I'm ready to get started.
less overall.
