Re: Tow/Haul or not Tow/haul..
Ok. So I researched this a bit to find out what exactly that button does to or for MY truck. For the 2007 Silverado Z71 I drive, the tow/haul button changes the shift charecteristics by increasing line pressure on the clutch plate packs, and increasing the engine speed at which the transmission shifts. It also allows for a faster shift, thus reducing slippage of components and preventing exsessive wear. It does not eliminate overdrive, which is any gear greater than a 1 to 1 ratio, but may cause the converter to not lock or lock at a higher speed. One of the recommendations was to use the tow haul to get up to speed, or when entering the highway, or of course in mountains and hills. Turning the tow/haul off during higway operation would allow the converter to lock and the transmission to run cooler. Hope this helps my fellow Chevy and GMC drivers out! Thanks everybody for your replies, and any additional comments or suggestions are always welcome.
