Re: 1989 Mariner II 150 overheating
.................. took off head and gasket and saw no water was completely dry...............................
As soon as you shut off the motor it drains out so you will never find the block filled with water when you pull the heads.
While you have the heads off, take a very close look at the old head gaskets to see if they have been leaking combustion gases into the water jacket, displacing water and causing your over heating.
Often the leak will not show during a compression test or at low speeds and low loads, but as speed and load increases, so does cyl pressure, once that pressure overcomes the gasket seal then it starts displacing water in the cooling system and you see steam from the P stream.
Check the block and heads for flatness so the new head gaskets have good surfaces to seal against, Follow the torque pattern and settings when tightening the headbolts.
