feedingfrenzy
- May 14, 2012
- 20
Hey Guys and Gals,
This is my first time posting on a boat forum, proberley because I just recently purchased my first boat! So I also recieved a 1969 Johnson 4hp 2 stroke. Hasnt been started in 15 years but the hard work is complete.....I think. I got it strated, first replacing the pull cord, 2 spark plugs, and finally sanding down the points which all rewarded me by turning over after a few pulls! I inspected the water pump as directed by a friend that has been boating for years. Rubber looks good but I bought a spare just in case.
My only and final problem is upon inspecting the oil reservoir (near the propeller where you put the gear oil) to check the condition and level of the oil, I noticed that I have a leak resulting in water mixing in. The oil was milky looking and clearly had water mixing in. I was told that I have to replace the seals. So my question to all of you knowledgable guys and gals is How Do I Go About Replacing The Seals?
I'm new to all of this but low on cash so I'm doing all the work myself. I'm good with mechanics so with a little guidence I should be all set to replace the seals.
Thanks for all of your time and any help you can provide me.
feedingfrenzy
feedingfrenzy
