Aerialshaman
- Jul 10, 2011
- 1
I have a 1980 Evinrude 75hp. It takes me about 4 or 5 tries to get the motor started and I have it in the Start position on the bar when starting. It will start up and tack up very high until I lower the bar. Then it will run fine and idle fine until I shut it off. Then I have the same issue again a couple hours later when starting. 4 to 5 times turning the key with it in the start position and then once again the same thing tack up high and then runs fine until I shut off the key. Just wondering where I should start with this issue?
Thanks
Chad
Thanks
Chad
