Hello again,
I was wondering if someone could advise me with respect to the proper placement of the low speed needle carb bushing on a 1958 Johnson 18. It appears that this cylindrical piece is round and flat-ended on the one end and a bit more tapered on the other end. I am trying to figure out which end is inserted into the carb body first. I have been having a little trouble getting the slow speed needle to stop floating a little when the engine is running. The carb has been cleaned and new packing washers are being used.She is running pretty good but that low speed needle moves a bit. I can't quite get the motor down to a troll speed but am getting closer. I can't tell from the parts diagram which end is to be inserted into the carb first, I thought that if the bushing was in backwards that might negatively impact the potential slow idle needed for trolling. When I try to slow her down that tiny bit more, she starts to sputter and quits. It starts right back up again when I increase the throttle slightly to restart. The needle is in excellent shape. Maybe the 18's weren't intended to go slow enough to troll?
As always I really appreciate your input.
Thanks so much.
Sean.
Lindsay, Ontario. Canada.
Thanks so much.
Sean.
