Mary's Boat
- May 14, 2012
- 1
I have a 1990 Johnson 225 hp outboard. I changed the water pump, because I thought there wasn't sufficient water flow out the top of the motor.When I inspected the old water pump, it still was flexible and no cracks or signs of wear. I put water ears on the motor and while it was running, I noticed water coming out between the lower unit and the mid section. Is this normal or do I have a problem leak.
