This is a 1969 Johnson 115HP. Compression is 125psi in three cylinders, about 118psi in cylinder #1.
My motor "loads up" when at idle speeds. Likes to stall out when I bring her down to an idle and then try to take off again. Then sometimes hard to start or keep started. Once you get it started, it once to die as soon as you give it gas. So I've had to manually move the throttle arm forward to get it past the stall phase and moving again. Not sure what the initial movement of the throttle is doing (it's opening something, but not really moving the idle arm until you move the throttle further forward), but if I move the arm forward manually, it quickly jumps forward and the boat is on plane again.
Last night, it was idle a little rough in my drive way, so I adjust the slow speed all the way to left, which turned the 4 adjustment screws out about a 1/2 turn. This smoothed it out. The linkage to the knob on the front of the motor and the adjusments arms is not intact.
I checked the fuel pump for leaks. It appears good. There was no fuel coming out of the vacuum line that attached to cylinder #1 when I pump the snot out of the fuel tank.
So, here is what I found: https://www.youtube.com/watch?v=d6S2uBgtn6o&feature=youtube_gdata_player
Is this normal? The top throttle plate is dry as a bone. The bottom one is spitting fuel out of the intake. There is gas all over the throttle plate and gas being ejected out towards the camers. But the top intake is bone dry.
Is this a problem? If so, what is wrong? Any ideas fellas? BTW, this old motor is on the original boat....I restored this 1970 Starcraft V180 about 8 years ago. New stringers, transom, floor, and interior. The rest buffed out and cleaned up. She's a beauty!!
Thanks in advance.
Steve
Thanks in advance.
Steve
