Cj7jeepoffroad
- Apr 27, 2012
- 62
I was running my 1988 Rinker with Alpha MR today on the muffs while I was tuning it up, I started it in neutral and had it throttled up to about 1300 RPM, I went back to the stern and it sounded like it was partialy jumping into gear, it wasnt jumping into gear the hole way but just enough to slowly turn the prop. It dodesnt do this at low idle and the prop doesnt turn, only at high idle. I just adjusted the shift cables and it shifts well. Any idea what is causing this? it it normal?
