reefrunner42
- May 13, 2012
- 4
I have a 25ft Scottie Craft cuddy cabin with an AQ225 linked to a 270 outdrive. I purchased the boat without the outdrive and received the 270 free. I believe it was off a houseboat. The gear ratio stamped on the lower unit is 2.15. At 3,000 RPM the boat only does about 10-11 mph. WOT puts me at 4100 RPM and about 14 mph. This seems very slow. I am looking at purchasing a lower unit with the correct V8 ratio of 1.61 to 1. My question is how much of an impact should this create? I would like to run at 3100 RPMs and at least 16-17 mph all day with 4-5 people headed offshore. Is this pheasible with the 225 HP motor? This would all be assuming I select the prop with maximum potential. Thank you for your help.
