Wingedwheel
- Jun 16, 2009
- 1,071
Hey guy's.
I have a '96 SeaRay 190 Signature with a 4.3 Mercruiser engine and an Alpha 0ne Gen II Outdrive. My problem is, when I pulled the boat out yesterday to do my yearly "get it ready to splash" routine I discovered that the trim pump would click when the switch was pressed but would neither trim in or out. I used the troubleshooting guide I found in the forums and determined that there was a problem with the motor. I began to remove the pump unit. but before I did I gave it one last try. To my delight it actually started working again. now the new problem. it works intermittently. I have to press the switch several times before the actual pump begins to work. The solenoids are working fine and I can tell they are both working correctly. So I suppose my question is does this sound like a dirty connection and if so, why is it doing this in both directions. The solenoids click loudly with each press of the switch so I know they're getting power. Do I need to clean the connections on the solenoids themselves or is there a different connection I should be looking for. thanks in advance.
