Re: Polyester resin no VOC's???
Is there a polyester resin with no VOC's and where would you buy it? I seen one on you tube that will dry instantly with a hand held UV light but that is the first i have seen.
The technology is there to do it, but the final product can be difficult to use and is pricy.
Some companies market styrene free resins as if they are better than ones with styrene, they just substitute a different monomer (Solvent, thinner) for the styrene that isn't listed as a harmful VOC, they aren't really any safer, it's just a loophole in the regs.
UV cure resins can be purchased, the problem is the cost of a UV cure light booth is so high companies don't want to invest in it. The UV cure initiator is rather pricy too.
