the reason i need one is because i live in south louisiana and go thru a lot of nasty low water, with duck weed, grass and just back water places and i need to check the water flow with just a glance.
HI mtitan. Sure you can add a tell tale. There are several methods, but the easiest might be to add a 90 degree, nylon elbow to the t-stat housing and route a line out of the cowl pan. Scroll about half way down the link below to see how it's done.
hi , im a newbie when it comes to boats, but the above link is the best ive seen yet, ive fixed so much and i havent spent a dime yet. tomarrow i buy new condensers and should trollin by saturday. the info on these forums is priceless, thank you , its awsome!
