1960 75 h p evenrude timing
boobie
Re: 1960 75 h p evenrude timing
Timing is set when you install the magneto drive belt correctly and have the points set to specs.
boobie
I think it should be TDC. Never thought about it as you aligned the marks in the flywheel with the crankcase and the the marks with the dist base to the marks in the mag pully.
