Re: Fine Tuning 1956 15hp evinrude Fastwin
Hello again bobberii. Looks like the motor is running good and pumping lost of water as it should. It's hard to see exactly where the water is coming from. Sometimes water from the lake/barrel just splashes up under the cowl. There are drainage holes to allow it back out. However, if the water is coming from beneath the powerhead, then you may have a bigger problem. Welch plugs are little, coin sized discs that can be found on the power head and carb bodies. They are designed to be removed so you can access various passages within the carb and motor. The one on the powerhead is about the size of a quarter and will probably have what looks like an "M" and/or some numbers stamped into it. You can get them from most OMC dealers. However, before you go that far. Check lindy46 idea of a missing driveshaft o-ring. You can check easily enough by dropping the lower unit and checking the top of the driveshaft for a small, black o-ring. It's about the size of your pinky finger. As the motor spins, water can actually "climb" up the driveshaft towards the underside of the power head. The little o-ring prevents it from getting quite that far. If/when water does reach the power head it can cause the driveshaft to rust and stick in place as well as leak, as you've seen. Give this a quick check, report back and we'll take it fom there.
P.S.
To drop the lower unit, you'll need to remove the small oval plate from the side of the leg of the motor and remove the lower bolt from the shift rod coupler. Now remove the 4-5 bolts holding the gearcase onto the leg. When all of the bolts are removed, the gearcase should drop out along with the driveshaft, lower shift rod shaft and possibly the copper water uptake tube. You can then check the top of the driveshaft for the o-ring in question. If it's there, replace the LU using the reverse procedure. If the o-ring is missing, you'll need to get a new one, which comes in a lower unit reseal kit along with the oil seals for about $25. You can get a kit right here at iboats. Good luck. Keep us posted.
