I just acquired a 2000 bass tracker. Ignition switch has 3 positions: off, run, and start. It was working correctly moving through all 3 positions. However, the switch was a little loose Around the dash and would rotate slightly when the key was turned. So I took it out of the dash and put a washer on it to make it tighter.
It worked but here's the problem now: when I go to turn the switch clockwise, it immediately attempts to start where before it would just move into the run position. I figured it may have gotten stuck in the run position because the fuel gauge stays on (when the switch is at off the fuel gauge goes to E). The switch won't turn counterclockwise at all though. Anybody know what my issue is? Also, I used vice grips on the switch, could I have damaged it?
Thanks in advance. If this isn't electrical, could mods move it to right place?
