I have a 98 waverunner 1100 I take it out and run it for any time longer than aprox 45min and I just shut it down when i go to start it up again there is no electrical powert what so ever no gauges no click no nothing. let it sit for 1 and a half to two hours fires right back up doing nothing else but letting it sit. now I was able to check a couple of wires when it was dead and the 4 wires that come from the start switch two connectors the connector with the red and the brown wire when i have no electrical power the brown wire reads nothing but when it will start the brown wire reads a direct connection to ground until i hit the start then goes to 12 volts
