Hi all,
I have a FrankenJohnson I am starting to play with...the body is a 1992 60hp (VJ60TLENE), but has a 1990 70hp powerhead (J70ELES) bolted on.
reason for swap:
60hp = beautiful condition/blown powerhead
70hp = Fugly/hit by tree/good powerhead
Anyway, the 70 didn't have T&T, the 60 did and I want to marry everything together. I am pretty sure the instrument wiring harnesses are different (at least by part numbers). I'm not sure if I really need to swap them or if I can use the harness that's on the 70. The T&T wiring I need to figure out. I have the Seloc manual, so it's just a matter of sorting things out....
In the meantime, I was hoping to get a few detailed pictures of similar motors of the same era with the cowls off...specifically, Left, Right & back side wiring along with T&T button wiring. I am hoping to see how the wiring was run and where the connections are made.
I don't have any reference as the 60hp powerhead was already disassembled when I got it. Pictures in the manual aren't helping me much.
Thanks for any help you are willing to lend!
DW
reason for swap:
DW
