Z on Crystal
- May 8, 2012
- 4
Hello,
Need some advice on changing trim sending unit on my 96 SX.
I have located the sender and where the wire goes thru the hull but my question is, How do you access it?
There is no room to get your hands into the lower unit to access it. Not even a long needle nose.
Inside is just as bad.
Do I need to remove anything to access inside and out?
Thanks for your help.
