Mercontrol 1150 115hp
Xshawnx
Well after buying this 1985 boat I found out that the control box is messed up. So I took it to the shop and they told me the cams inside the box are worn out and I need new ones, it's also missing a pin that apparently they don't sell anymore. So I was wondering if anyone had these cams and pin and maybe just the whole box that I can buy? Thanks
carholme
Re: Mercontrol 1150 115hp
You can order the parts from them or use the p/ns to do some online searching.
Gerry
Xshawnx
Awesome thanks! I'm also in need of a port side trim cylinder. Any ideas?
Xshawnx
It's at the shop right now but If I remember right it's 5383830?
Chris1956
Reseal kits may be available for the trim cylinders. A special tool is needed to reinstall the piston and teflon seal.
