2 tubes from Ski pylon
magicman1223
My 2001 q3 has a ski pylon that we use to pull a tuber. What I am wondering is do you think it would be safe to try and pull 2 tubes from the single pylon? The each tube would have 1 full size adult maybe 200lbs.
whmoore18
Re: 2 tubes from Ski pylon
Me personally I wouldn't. If they aren't set on either side of your wake or anything happens you might have a nasty collision. Get yourself a banana boat deal or a tube that seats two on it and I think you'll be a little safer. The tow pole should be fine holding it
magicman1223
So the pole held fine with both tubes. However you have to get accustom to trying to avoid the other tuber. :) it was fun though.
whmoore18
No thats what I'm saying I don't think it will thats alot of drag plus you better have one hell of a motor to get out the hole with that weight
