I have a 2008 Mercruiser 3.0L 135hp 181 cid TKS engine in my boat. It idles fine and the high range is also fine. It stalls in the middle range 2000 rpm - 3000 rpm range. It started this issue the beginning of this season. I believe it is getting flooded, because after it stalls and i start it back up with no throttle at all it reves high for a few seconds before it goes back down to normal idle. For a few seconds it revs high and low and then goes down to idle when hot.
Has anyone had this problem before and do you have any suggestions? I'm hoping it is not the mid range circuit on the carborator. If it is I may have to rebuild or replace the entire carborator.
