140 hp evinrude. 1985 tilt lifts the motor. but doesnt lower
dej
I have a question about the hydraulic lift for my 140 hp 1985 evinrude. It lifts but wont lower. I hear the relays click. Im sure i have power going into the two wire motor. Any advice would be greatly appreciated.
mark1961
Ensign
Re: 140 hp evinrude. 1985 tilt lifts the motor. but doesnt lower
Can you hear the trim motor running when you try to lower it?
dej
Motor doesnot sound or hum in when trying to go in down position. Runs fin going up
Daviet
Try swapping the relays and see if it works in the other direction.
dej
Thanks i will try that
dej
Yes lowers now it has a bad relay thankyou sir very much
