water flow question
mbailey17
Just recently bought a 22' Macgregor sailboat that came with a 85 Johnson sailmaster 8 outboard. I am relatively new to boating and outboard engines so please excuse my ignorance. Put the engine in a tank & got her running with a little cleaning of the carb but noticed there appearred to be no exhaust in the tank. no water exhaust or engine exhaust? there was a stream coming from the indicator at lower back of the engine and engine exhaust from the exhaust relief(?) as labeled on the manual. but nothing in the tank?
any help opinions or observances will be appreciated
MB
Chris1956
Re: water flow question
Well the exhaust has to go somewhere. Most of the exhaust likely came out exhaust relief, as you were not moving forward to pull exhaust out of prop area. Water was being discharged near the prop, but it is hard to see.
mbailey17
I felt in the tank around the prop shaft (the prop was removed) and felt no kind of exhaust no movement in the tank or any kind of agitation...this is normal???
mbailey17
ok guys what did I do wrong?
I know there at least 1 person in the 143 people that viewed my post that could answer my question but no one has?
so what did I do wrong in my post?
nwcove
you did nothing wrong in your post. jmo, since the motor is a longshaft?or extra long, it probably was submerged enough in the barrel to create enough backpressure in the midsection to allow all the exhaust ( or most of it) to exit through the upper relief.
mbailey17
Well That explains alot. thanks!
but what about the return water?
Chris1956
Maybe the thermostat never opened. That would simply recirculate the water with minimal discharge.
