Hey guys. I was troubleshooting a low RPM condition on WOT and found out I have an outdrive with a much lower gear ratio than I thought it had (1.47 vs. 1.81), so I'm hoping for some advice on which prop I SHOULD be running. The details are as follows:
1) Performance issue you are trying to correct: Low RPM and power at WOT
2) Current prop manufacturer, model, aluminum or stainless as a minimum: Unknown manufacturer or model. Geometry of the prop is good but the numbers on it have been obscured. It's a heavy prop so probably steel.
3) Current prop diameter and pitch (required): Unknown pitch (see #2 above)...diameter is 15.
4) Wide open throttle RPM and speed with an average load (very helpful): RPM at WOT is 2600, speed less than 20MPH.
5) Engine/drive make, model, year, and HP: 1995 Mercruiser 4.3LX (0F586331), Alpha one, Gen II, gear ratio 1.47.
6) Boat make model, year, length and weight 1995 Wellcract 218 Coastal, 21ft 8in long, 3300 lbs dry weight.
Thanks in advance.
Thanks in advance.
