I have just replaced a 4.3L mercruiser and re installed the alpha one leg. (Bayliner, 4.3L Motor and drive are from 94) In the driveway it shifts forward to reverse very smooth. Idles around 650rpm. But in the lake while docking it required excessive force to shift between forward and reverse. Back on dry land it shifts fine. The cables seem to be in good shape and slide smooth. When the drive was off I could easily shift the drive in and out of gear. I figured maybe the throttle cable was out of adjustment causing it to bind in neutral but that theory does not hold water as it shifts fine in the driveway. My manual has a step by step cable adjustment I was going to do this week but figured to harm in getting a bit more education before possibly going down the wrong road. Could this be incorrect pre-load on the cables? At the lake, there were a few times after pulling the shift handle back to neutral that I suspected the drive was still in gear. There was a bit of wind and I did not suspect an issue at this point so I did not double check, starting me thinking adjustment. I have read many of the other posts on this topic but have not been able to draw any concrete conclusions. Any tips would be appreciated.
